First post, by divinity
i tried DosBox 0.73 with different dosbox.conf configurations
under Ubuntu 9.10 and the Sound stutters extreme.
Under Windows everything works fine.
Does someone knew a solution for my Problem?
Reply 2 of 18, by wd
Rank DOSBox Author
DOSBox Author
Too much ubuntu hatred 😀
Reply 3 of 18, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
the prebuffer setting was for Linux right?
1+1=10
Reply 4 of 18, by divinity
tried 1, 10 and 20 as prebuffer with no good result.
Reply 5 of 18, by rcblanke
Maybe try 44000 for sample rate.
Reply 7 of 18, by rcblanke
hehe oops 😀
Reply 8 of 18, by divinity
ok, 44100 does not work - same stuttering as ever
Reply 9 of 18, by Qbix
Rank DOSBox Author
DOSBox Author
kill pulse audio and/or get a sdl specificly for pulseaudio
Water flows down the stream
Reply 10 of 18, by wd
Rank DOSBox Author
DOSBox Author
Or kill ubuntu. DosFreak's right. Maybe in a few years they'll get their audio fixed.
Reply 11 of 18, by Raymond C. Glassford
Good advice, and probably the only way out. Linux operating systems are not created equal. I had sound stuttering and lagging problems with DOSBox 0.72 (compiled from source) under Mandriva Free 2007.0. I am now running DOSBox 0.71 (RPM package) under PCLinuxOS 2009.4 LXDE, and sound is perfect, with no tweaking other than setting "cycles" for individual games. The PCLinuxOS install went very smoothly and configured my sound system automatically.
DOSBox 0.73 under Windows XP, by the way, also works flawlessly for me. No sound issues at all.
Reply 12 of 18, by valnar
Interesting. I had played with Ubuntu in the past, but I'm not really a Linux guy. I was just thinking of loading it up again....but maybe not.
What would be a better distro? Is Fedora or SUSE any better regarding sound support? I'd like to stick with a top 5 distro.
Reply 13 of 18, by robertmo
ubuntu leader said he is impressed by windows 7. I think no more comment is needed 😉
Reply 14 of 18, by Raymond C. Glassford
valnar wrote:
Interesting. I had played with Ubuntu in the past, but I'm not really a Linux guy. ...
Linux distros can vary greatly in usability and popularity between releases, so do not place undo emphasis on "top 5", "top 10", etc. ratings. I have used only two Linux distros -- Mandriva Free 2007.0 and PCLinuxOS 2009.4 LXDE -- but I don't see how PCLOS can be beat for ease of installation and hardware detection. My present install -- PCLOS LXDE -- has my former install beat in every respect. Most importantly, ALSA was installed and configured automatically, and my sound system works perfectly. So, keep things as simple as possible and I'm sure you will be pleased.
Reply 15 of 18, by wwwolf
I had this problem myself, Ubuntu 9.10 64-bit, DOSBox 0.73, and Under a Killing Moon.
Found an answer here: https://bugs.launchpad.net/ubuntu/+source/dosbox/+bug/429373
Long story short, set playback rate to 44100 and buffer to 50 (or even 100) in your DOSBox config - it worked for me.
Linux may not be perfect, by a long shot, but its a heck of a lot better then it was even a few years ago.
Reply 16 of 18, by divinity
Yeah this solution works for me! Thanks a lot wwwolf.
Reply 17 of 18, by kruwi
Switch to plain debian. why use the copy if there is the original?
Visit the end of the internet: www.groskreutz.de
Reply 18 of 18, by temptingthelure
Well, most sound problems on different distros have been traced back to the same source, PulseAudio. Dont know why modern distros keep using that buggy library. Uninstall it, install SDL instead and the sound problems are corrected. 😀
Rise of the Triad modding site!
http://rott.s4.bizhat.com
