First post, by nikiniki
- Member
Hi
Shadow Warrior freezed after I defeated the first boss.
I selected 800x600.
The game runs fine if 320x200 is selected but I'd like to use higher resolution.
Hi
I selected 800x600.
[Moving to the Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Which version of DOSBox?
Dosbox 0.73.
where have you got your dosbox from?
what is your Operating System?
what are your PC specifications?
post your exact mountings
post what is written after you mounted
post content of "DOSBox Status Window" before running the game
enclose your dosbox's config file
The dosbox webpage
windows vista
Vaio 4gigs, laptop
c:\dosbox\dosbox C:\ShadowW -conf dosbox.conf
see the picture
Here the picture
Obviously that's no config file from a 0.73 installation, and then it doesn't
look like you installed it correctly/kept the right mountings.
Hi
I created go.bat file to run Shadow Warrior.
In GO.BAT
When I erased dosbox.conf from SW directory, a new one was created at c:\users directory not from the game. I'd like the config was created in the game directory like Dosbox did with screenshots.
Also I changed svga_s3 to vesa_nolfb
Now, the graphic look better
But the game still crashes in the boss battle.
Here the dosbox.conf
try other versions of dos4gw.exe
DOS Memory Extenders - by Snover and DosFreak
try disabling xms and ems
I just found the problem. Because you play SW in higher resolution, it needs more memory.
In config file, change memsize=16 to memsize=32
Shadow Warrior works fine this way.
