First post, by skttrbrain
Hello All...
I wonder if someone could tell me how F-15 Strike Eagle II is supposed to behave under DosBox 0.73...
I bought a nice F-15 of eBay, complete with all the box contents in very good condition, but I am a little worried the disk is on its last legs...
I normally play of images of my original disks but this disk does indicate that it has a couple of bad sectors when I image the disk...
I installed it anyway from both the original diskette, an .img and the disk contents copied to a folder and that mounted as the floppy drive. The install went perfectly in all cases.
I ran it as instructed using the f15.bat but there it hangs with 'echo on' and gets no further... could this be DosBox or is it likely my disk...??
Any help would be much appreciated...
