First post, by realnc
- Oldbie
I'm using DOSBox 0.74 and also tried SVN. I'm on Linux 64-bit.
Timidity is running in the background (128:0). Playing midi files with "aplaymidi --port 128:0" works OK. However, DOSBox will not play MIDI in any game a tried, unless I have a MIDI file playing with aplaymidi before starting DOSBox. As you can imagine the result is a cacophony of notes, since both the game's music as well as aplaymidi are audible at the same time 😜 Digital sound also stops working in that case. I tried both "uart" and "intelligent" for mpu401, to no avail.
Is there any way to fix this?
