First post, by Hazekel
I searched the forums but couldn't find the answer to this one.
I managed to install Windows 3.11 for Workgroups under DOSBOX. I want to use it to run a very old Windows game (it won't run under DOS). When I attempt execute the game it says it requires 256 colors, so I go back to Windows setup and attempt to install one of the 256 color videos but none of them work. Is there a trick to this? Since DOSBOX emulates DOS and I get 256 colors in DOS games, why cannot Windows 3.11 load a 256 video??
P.S.
Should I actually get this working, is there a shortcut I can make in a BAT file or something to load the game inside Windows without having to run it manually? I mean like "dosbox c:\windows\win.com -run wingame" or something like that? Sorry, I know that is two questions. The first is the most important.
Reply 1 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Use the s3 drivers in the guide and select 256 colors. Or elaborate the "don't work" part of your post.
There is a way to start a windows program like that, but I don't remember 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 8, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Look at the DOSBox Guides section of this forum
1+1=10
Reply 3 of 8, by SKARDAVNELNATE
What I do is load the AUTOEXEC.BAT file from DOSBox. I edited it adding this at the end:
IF %1==SKIP GOTO END
IF %1==SETUP GOTO SETUP
WIN
GOTO END
:SETUP
CD WINDOWS
SETUP
:END
It helps automate installing S3 Video and Sound Blaster. You can add a shortcut in Windows 3.11 with "File > New > Program Item".
After "WIN" you can place the path to the program you want to run.
WIN C:\PATH\FILE.EXE
Reply 4 of 8, by Hazekel
Ok. I was finally able to get the video drivers working and I added the SB16 drivers, but when I start Windows 3.11 I get a continuous beep as the MIDI doesn't seems to be able to stop playing. How can I fix this? It appears to have something to do with the default MIDI drivers, but how do I change it. I already installed SB16 as per the DOSBOX installation instructions and it shows up in my Control Panel, apparently working except for the continuous beeps.
Sorry to be a pain, but it has been ages since I actually used Win3.11
Reply 5 of 8, by SKARDAVNELNATE
I've haven't heard that happen. Usually it either works or you get no sound.
I extract SB16W3x.zip to C:\WIN311\A
MOUNT C C:\WIN311 -t dir -freesize 400
Then launch AUTOEXEC.BAT SKIP
Ignoring the part that gets shipped over the end of it looks like this.
:END
CD A
INSTALL
During install it requests to replace a file so I select proceed.
When it's done F10.
Reply 6 of 8, by Gamecollector
Continuous beep is SB16 drivers issue...
First I load drivers from creative.com and - beeps are here...
SB16 drivers from "dosbox guides" topic - no continuous beeps, all works perfectly...
Now I can at last test my "Critical Path" copy. 😀
Reply 7 of 8, by Hazekel
I just had to change the IRQ to 7 from 5 and it worked.
Now the last question ... sorry to bug everyone ... is how to make a bat file that will start windows 3.11 and immediately run the game I have set up in Windows. Is that possible? It would be nice to just click a single button to start up everything.
Thanks
Reply 8 of 8, by Gamecollector
win %your_win311_program_name%.exe
