First post, by Gridseeker
I bought through Ebay a original copy in CD of Super Street Fighter 2 Turbo. The game works perfectly in DOSBOX but there`s no sound, even I configured it correctly in the Setup program. Someone had the same problem? I run it in my notebook, a Dinabook Toshiba Celeron 1.5 Ghz.
Reply 1 of 19, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
How do you configure sound for this game?
Reply 2 of 19, by leileilol
You use the setup program. It works for me and I have sound.
FUCK "AI"
Reply 3 of 19, by Davros
does it autodetect or do you have to select a soundcard
if so what one do you select
Reply 4 of 19, by Gridseeker
I can only choose in the "INSTALL" setup program the sound cards from the Sound Blaster family (the Soundblaster ASP/16 is the one autodetected), other types like Gravis or Adlib just gave me the error message that I dont have the drivers. Well, the fact is I got SFX sounds but there`s no music from the CD the game and not mention the game becomes slow as a snail when the first match begins (odd when the intro, the menu screen and the character selection screen runs very well). About the port, DMA and IRQ settings, I`ve chose the ones detected by the setup program (220, 1 and 7 respectively).
Reply 5 of 19, by bloodbat
I don't know if it uses CD music...if so...is the CD mounted while playing?
Reply 6 of 19, by leileilol
SSF2T supports both MIDI and CD music. IIRC a patch enabled midi music in the full game
And if it's slow as a snail, try a different output mode like ddraw or opengl. Your notebook may not have a 8bpp friendly video controller
FUCK "AI"
Reply 7 of 19, by Gridseeker
Wel, I haven`nt mounted o created an image, I just insert the CD and run it. BTW leileilol, how I can set a different output in Dosbox? Is there any way to play the music from the CD without create an image?
Reply 8 of 19, by bloodbat
Without mounting a CD or image, it's no wonder you get no music, DosBox isn't aware the CD is there...so...there.
Reply 9 of 19, by schlang
there are some revisions of that game where the CD came without the CD audio tracks
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 10 of 19, by Freddo
I really doubt that. Sounds more like a poor rip.
Reply 11 of 19, by Gridseeker
Bloodbat, you`re right! A few moments ago I created an ISO image and now works perfectly and the SFX sound is smooth, however it still lacks of music. Somebody know how I can get the music from the CD? Has anyone had the same problem?
Thanks Bloodbat!
Reply 12 of 19, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Create a bin/cue image of the CD OR mounting the CD Rom as CD Rom and trying out the two possible CD Rom smount settings....
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 13 of 19, by Gridseeker
First of all, thanks a lot for the help folks!
Dominus, can you explain me how to do that and run, please?
Reply 15 of 19, by VenusHeadTrap
To Gridseeker (and anyone else)
I bought a CD copy just like you on March 23rd, unbelievable as this was the same day you made this thread.
First post, so I'll be back with more.
But my question is: How did you get SSF2T to run with DOS Box?
Reply 17 of 19, by VenusHeadTrap
Okay! Managed to get the game running fine on Windows XP.
Now I found out my problem is slow down during fighting matches on SSF2Turbo. All the menus are normal, and music plays fine, but when I actually get to a match, everything buffers and it freezes before the fight starts.
I read something on what to do if you experience slow down, but I don't recall where I found it.
Can someone point me to the troubleshooting page?
Reply 19 of 19, by Gamecollector
Nay, only "Super Street Fighter 2" was without CDA.
