First post, by Noiz
First up, new version.. Woohoo!!!!
I was so excited about protected mode support cos it meant I might finally be able to play the original Need for Speed again... Alas it was not to be.
On trying to install the game I get a message saying:
"setstreamspeed - frontend\movielow\ea.tgv FILE IS TOO SMALL TO ESTIMATE DATA STREAM SPEED
Size is -8192. Require 20000."
I'm guessing it's trying to find out how fast the CDROM is but failing miserably. Not sure if it's fixable through the config, but I'm wondering if anyone's actually got it installed on a PC somewhere and is able to send me the files it makes (just a few config files), then it might be a nice workaround.
Soooo, if you can help, or if you've got the installer working on your machine then please let me know! Much appreciated 😀
Mike
