First post, by griphus
Has anyone gotten it working properly in DosBox? I've seen documentation online claiming that it works, but I can't make it do so. I mounted the installation files as the A drive, installed it (it worked), and I get the "Corrupt Config.DAT" message when I try to run it (same kind if you try to run it as a DOS program in windows). I've tried it with both Sound Blaster and PC Speaker and neither setting works. Thanks.
