KQ6 problem
First post, by sambrea
Hi, I'm trying to run the GOG version of KQ6 for speedrunning and I'm having a problem where dosbox will just suddenly crash to the desktop without warning. I'm not sure what' causing this or how to fix it so if someone out there can help me, I'd be very glad of it.
Reply 1 of 21, by bloodbat
Speedrunning an adventure...that's odd.
Make sure you have the latest drivers for your hardware before going further.
Check the GOG forums to see if other people that bought the game experience the same crashes as you (and how to fix them, if they did).
Anyway, help people help you:
-OS
-DosBox version and configuration (specially video and cycles).
-Mountings.
-King's Quest configuration.
-Does it crash somewhere specifically? Or at random?
-Does it crash when starting from the beginning or only when loading a saved game?
Provide as much information as you can and as detailed as possible, otherwise...you won't get far.
Reply 2 of 21, by Jorpho
There should be some sort of error log in the main DOSBox directory, I think. [EDIT: It's called stderr.txt , and it only appears if DOSBox is started with -noconsole , which is standard for GOG's shortcuts.]
If you are taking pictures or recording movies, DOSBox will crash without warning if there is not enough space on the partition where it is trying to save the data. (I noted that three years ago, anyway.)
Reply 4 of 21, by sambrea
I want to post my diaxdg file to see if someone can help me but I can't figure out how to add it to a reply?
Reply 5 of 21, by bloodbat
Don't, I said to post mountings, DosBox version and config, and such, reread my post, I never said dxdiag.
Reply 6 of 21, by sambrea
-OS Windows 7 home edition
-DosBox version and configuration (specially video and cycles). .74, I've been playing around with the graphics configuration but nothing seems to fix it
-Mountings. ?
-King's Quest configuration. gog.com version
-Does it crash somewhere specifically? Or at random? Three separate times, once while starting to climb the cliffs of logic, once while on the isle of mists for the second time, and once in the secret passage of the castle
-Does it crash when starting from the beginning or only when loading a saved game? only specifically during those times, not while loading or starting the game
Reply 7 of 21, by IIGS_User
sambrea wrote:
-Mountings. ?
Find "Mount" in the configuration file.
Klimawandel.
Reply 8 of 21, by Jorpho
As I asked in my earlier post:
Is there a file named stderr.txt in the same directory as dosbox.exe?
Do you still have free space on your hard drives?
Reply 9 of 21, by sambrea
IIGS_User: I'm using the GOG version, which only has a graphics configurator, there is no mount listed there.
Jorpho no, I don't see that file, and yes I have plenty of free space available, around 75% free.
Reply 10 of 21, by collector
The stderr.txt will probably be found in the game's folder or possibly in the Virtual Store.
Did you try to remove the "exit" command in the game's conf file? If it is the game crashing instead of DOSBox itself, you should see any error messages.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 11 of 21, by bloodbat
Did you look around and ask in the gog forums to see if anyone else has the same problem?
Reply 12 of 21, by sambrea
how do I open the conf file?
And yes, I did post it to the gog forums asking for help, but no one answered me, maybe I'll try that again
Reply 14 of 21, by sambrea
I removed the exit command but it's still crashing. What other things can I change in the conf files to fix this? Any ideas?
Reply 15 of 21, by collector
Then DOSBox itself is crashing, not the game. Try changing the conf to just:
[cpu]
core= normal
cycles= 10000
[autoexec]
cls
mount c .
c:
cd \
SIERRA.EXE .\RESOURCE.CFG
exit
And see if it still crashes.
Reply 16 of 21, by sambrea
When I put that in, I get the box popping up that shows it's dosbox but the game doesn't load. Here's what it says originally (I saved it before trying that, thank goodness):
[autoexec]
# Lines in this section will be run at startup.
mount C "..\King's Quest 6"
c:
cls
I played it after adding that cpu section and it still crashed
sierra
Reply 18 of 21, by sambrea
ok
Reply 19 of 21, by sambrea
After completely uninstalling (including saves) I did a quick run but it is still happening. If you want to see what I'm dealing with, I'm streaming some of my attempts, this is my latest full run with three separate crashes. The first one happens not long after 18:15.
http://www.twitch.tv/sambrea/b/417426241
