Daggerfall installation
First post, by Ragnar
I have downloaded DosBox, but am unable to install Daggerfall from CD (through DosBox) due to the problem that it does not see any install drives when prompted.
I have tried to manually install, but using XP renders this unusable
can anyone help?
Reply 1 of 5, by ValiantX
I remember having some problems with Daggerfall too. I think I managed to install it with VDMSound.
It doesn't see any install drives? Isn't it possible to just mount an empty folder as C: ?
Reply 2 of 5, by Ragnar
yeah....tried mounting game dir as C: but install still sees no install drives available
Reply 3 of 5, by CHARLES HOSTESS
Bump because I'm havin' the same goddamn problem too. My OS is Win 2k and if anyone could help I'd greatly appreciate it.
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
well maybe the next version will help you.
I added some missing (rarely used) dos calls which could be used as a disk detection system.
But as I do not have daggerfall cdrom I have no idea if this solves it.
Water flows down the stream
Reply 5 of 5, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
I tried today Daggerfall CD in the current CVS, having mounted C as harddisk, D as CD-ROM, using minimal installation in Daggerfall installation program - no problem at all. 😀 I did not test 0.61.
So wait for the next version.
Mirek
