First post, by benkid77
Hello,
Legends of Valour runs fine under DOSBox 0.61 and 0.62, but shows one minor problem on both versions. When you click on certain specific buttons on the 9-button control keypads at the bottom of the screen during play, a copy of the mouse pointer is left permanently on the background image. Not all of the buttons reproduce the problem, just a couple of them.
Repeated clicking on these buttons causes repeated copies of the mouse pointer to overwrite previous ones on the screen.
I've never played the game under real DOS so I don't know if the problem is a DOSBox issue, or a problem with the game itself.
The game is obtainable from the home of the underdogs (listed as "Legend of Valour" on that site)
My system is Geforce FX5600 with latest forceware drivers, Athlon XP 2800+, Abit KV7, via chipset, PS2 mouse, WinXP SP2
Thanks, benkid77
Reply 1 of 6, by benkid77
Further to the above message, I have also replicated the issue in DOSBox 0.63 and also on multiple computers. I attach an image of showing the mouse pointers remaining on the screen over certain buttons. I'd be interested to see if anyone else has reproduced this problem or otherwise,
Thanks, benkid77
    29.67 KiB
    A screenshot showing the mouse pointer issue
Reply 2 of 6, by Xian97
I remember playing it under real DOS years ago and didn't have any pointer issues that I can recall. I will see if I can find my old disks and try running it under DosBox with them.
Reply 3 of 6, by benkid77
Thanks for testing it if you do manage to find your disks. I only had the atari ST version previously, so I've only had access to the underdog's version of the game for testing with dosbox.
Reply 4 of 6, by wd
Rank DOSBox Author
DOSBox Author
Looks like reset mouse (int33/ax=0) needs to hide the
mousecurser, qbix might tell you more (at least it works
correctly then).
Btw. position mouse (ax=4) should respect the min_x/min_y, too,
as seen in the game.
wd
