First post, by ssybesma
The attachment Lemmings.jpg is no longer available
The video of each level intro screen looks rough. This is always right after hitting F1 from the opening screen...but that is the only place it looks wrong.
I've tried a couple settings in the video section but this is the current one I have. Any suggestions?
fullscreen=false
fulldouble=false
fullresolution=1280x1024
windowresolution=1280x1024
output=opengl
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
usescancodes=true
    671.34 KiB
Reply 2 of 7, by ssybesma
Jorpho wrote:
You're using a version installed from original disks, right?
Yes, I had them archived from many years ago when I copied each of the 3 5-1/4" disks to my HDD.
I remembered when you try to do it that way, you need to zero the first byte (and make file read only) to keep RUSSELL.DAT from increasing its count until it reaches 9 and asks for the floppy disk.
Reply 5 of 7, by ssybesma
466.47 KiB
Looking a lot better now with these settings although the DOS text looks a bit tortured. I set on VGAonly as you suggested. I'm just trying to get the window to stretch bigger than 640x480 and it's doing that now.
On a 1920x1080 monitor the VGA window is normally very small, so has to be stretched.
fullscreen=yes
fulldouble=yes
fullresolution=800x600
windowresolution=800x600
output=ddraw
Forgot to add...with output=overlay, the display is 'doubled' and shifted down about half an inch while using the rest of the settings above. That's why I have to use a different output.
Reply 6 of 7, by ssybesma
I couldn't get a screenshot of the problem so I took a picture. It's doubled anytime I set output to anything other than DDRAW. The bottom scroll is shifted down much further than the rest of the display.
Unfortunately, DDRAW does a hack job on the DOS text and makes it look rough. So have to figure another solution to get what I want.
    1.98 MiB
Reply 7 of 7, by ssybesma
Gave it one more college try...and finally this time with the settings below everything is perfect (so no screenshot needed): the opening screen, the screen after hitting F1 and the DOS text is sharp:
fullscreen=yes
fulldouble=yes
fullresolution=original
windowresolution=1024x768
output=ddraw
