First post, by SergeyW
I have game (version 1.2) and 3dfx patch
when i trying to patch the game-to get 3dfx- it says:
"enter directory where your shadow warrior game is installed (by default it's C:\sw"
i installed game in c:\games\sw
continue" -dossbox asking - "enter directory where current system resides"- i type C:\sw (right?)
and after that it gives me error - veryfying-failed
eut0008 internal error fileio. c 421
and c:/>
What i need to type to tun this patch?
Reply 1 of 9, by Jorpho
It depends how you mounted the game's directory in DOSBox. Did you type "mount c c:\", "mount c c:\games", or "mount c c:\games\sw" ?
Reply 2 of 9, by zirkoni
Why would you want to apply the 3Dfx patch anyway? IMO, the 3Dfx version looks worse than the SVGA version. I think the 3Dfx patch was experimental/alpha.
https://youtube.com/@zirkoni42
Reply 3 of 9, by SergeyW
ah ok thanks. i thought about that, because it says in Nglide compatibility list - no high resolutions
Reply 4 of 9, by leileilol
The way SW3DFX renders isn't very scaleable. It's still practically a software renderer with mild 3dfx-assisted bilinear filtering. There's no huge graphical gain nor is there a performance gain. It's only a morbid curiosity. Hell, it still works with palettes and lookup tables to shade the world so there is no added color precision either.
Reply 5 of 9, by MrFlibble
A while ago I managed to run the 3dfx version in 640x480 (default is 512x384) under DOSBox SVN Daum with nGlide. I don't remember if higher resolutions worked. It runs fine but indeed offers no inherent advantage to the software mode, even less to rendering options in source ports. Also there's a weird bug with sloped surfaces always rendered at full brightness.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 8 of 9, by lightmaster
MrFlibble wrote:
Sure, I have contributed some to MobyGames (including one comparison of the same scene in 3dfx and software mode):
http://www.mobygames.com/game/dos/shadow-warrior/screenshots
A few more shots can be found here.
Very interesting and useful, thank you!!
Reply 9 of 9, by MrFlibble
Note though that at least some screenshots are excessively blurry because I used output=opengl and some of the shots were recorded using FRAPS instead of the built-in screen capture tool. I should have used output=direct3d I guess.
Also the duke4.net forums thread I have linked to actually gives the answer to why patching doesn't work for the OP:
Be sure to use DOSBox SVN Daum when patching the game, because Apogee/3DR used to configure their RTPatches to check the date stamps of the updated files, and regular DOSBox and Gulikoza's build do not allow programmes that run inside DOSBox to modify file date stamps - hence the updated files will have the current date and time, and the patch programme will abort the updating process.
