First post, by Ron
Ron
Offline
I have games on floppy diskettes (1.44MB). I can install them using the command line. I tried doing so on Dosbox - after defining Drive A (mount A A:\). The installation started fine with the first diskette, but then I did not receive the message "put diskette no. 2 in drive". I had to quit the installation. Why is that happens? Is there special command to type in addition to "mount A A:\"? It is not really a problem, because I can install the game using the command line, but I am curious.
