First post, by lfl_038
I have made a software under Turbo Pascal 4 which was running on MSDOS 6.2.
This software uses specials characters in the filename of the file used to save the configuration.
The filename is chr(255)+"FONC-DE.F"+chr(255).
The file provided could not be read under DosBox 0.74 so I tried to generate a new one under DosBox 0.74 without any success (same error).
I have read all DosBox documentation available but I did not find any answer.
Could you please confirm that DosBox does not accept special characters in filenames ?
If you want to test, a download zip file is available here or attached.
Thanks in advance,
Best regards.
Appr871Dos.zip
99.81 KiB
89 downloads
Sample program using special filenames which is not working under DosBox (sorry program is in french language).
Reply 2 of 4, by lfl_038
I just check the code, in fact the character used is not char(255) but is char(127).
It seems this character is not working in DosBox as, when I updated the code, removing these characters, the program is working (see attached).
So, can you confirm that char(127) is not allowed in a filename in DosBox ?
Thanks in advance,
Best regards.
Appr871DosBox.zip
99.78 KiB
94 downloads
Update program working in DosBox.
Reply 4 of 4, by lfl_038
Thanks for your reply.
If you can add it in the allowed list, it could be great.
If, not, this is not critical as I could build a special version using file without this character.
Best regards.
