First post, by coleca
Hello.
I'm yet another person with a problem getting Privateer to work in DosBox. I've had little problem getting it to run on my WinXP system, although it is a little slow. I would actually like to get it to run on my Mac laptop. When I use DosBox 0.63, set ems=false in my dosbox configuration file, and invoke priv.exe, DosBox exists with the response "Exit to error: Illegal descriptor type 0 for int E"
I have no idea how to interpret this. It doesn't seem to matter what sound settings I use for Privateer or DosBox, if this helps.
Any help is appreciated.
EDIT:
I don't know if this is really necessary, but...
The system is a PowerBook G4 with a 1.33 GHz PowerPC G4 and 1 GB of memory. The OS version is 10.3.3.
