First post, by mrfusker
Hello.
I have a problem by saving a game in Manchester United - The Official Game. I'm using dosbox 0.65, and I have mounted a local directory as my floppy drive (my computer doesnt have a floppy drive). MUFC cant accept the local directory as a floppy drive! What should I do?
Reply 1 of 12, by cuttock
Is the emulated floppy drive labeled "-t floppy" in the autoexec area of your Dosbox config?
Reply 2 of 12, by mrfusker
My autoexec - Where should I put "-t floppy" ?
[autoexec]
# Lines in this section will be run at startup.
mount a E:\U-Spil
mount c E:\u-spil
mount d D:\
mount e F:\
Reply 3 of 12, by eL_PuSHeR
mount a E:\U-Spil -t floppy
Drive letters A and B are usually reserved for FLOPPY DRIVES.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 12, by mrfusker
MUFC still reports the same issue 🙁
Reply 5 of 12, by wd
Rank DOSBox Author
DOSBox Author
Always the same error message? What exactly?
Reply 7 of 12, by wd
Rank DOSBox Author
DOSBox Author
Most likely some low level disk access, might/might not work when
booting msdos using disk images and having that game disk mounted
as image as well.
Do you happen to know if the game disk itseslf can be booted? Like
command.com is present there.
Reply 9 of 12, by wd
Rank DOSBox Author
DOSBox Author
Then see above (create a bootable drive, imgmount the floppy image).
Reply 10 of 12, by mrfusker
I created a virtual floppy drive in Windows and mounted it in dosbox as A:. It didn't help.
Reply 11 of 12, by wd
Rank DOSBox Author
DOSBox Author
This will only have an effect if you boot msdos/freedos using another
disk image. Have a look at the guides forum for how to do that.
