First post, by WayneCa
I have a Pavilion 64-bit (Intel Core i5-6200U 2.3/2.4 GHz) Windows 10 notebook computer, with a 1 TB drive and 6 GB of RAM. I installed the 64-bit version of DOSBox and have been using it to play the MS-DOS variant of the game Soko-Ban for a while now. It works flawlessly. Recently I decided to play Wolfenstein 3D for the first time since I had my Windows 200o tower, Pentium II, and I don't even remember how much storage or RAM. I used DOSBox then and it worked flawlessly. I wish I could say the same now. The DOSBox window continually loses focus right in the middle of battle. I've tried remapping the CTRL key (fire button) to the Left SHIFT key (and subsequently had to disable sticky keys because of it), but the window still loses focus.
About the game setup:
I found a link to a shareware version of Wolfenstein 3D that was already setup for use with DOSBox. I copied all of the 6-episode files to the directory the shareware game is in, renaming the shareware executable to Wolf3D1.exe. The contents of the .bat file I drop on the DOSBox icon is as follows:
@echo offconfig -set "render aspect=true"loadfix -25cd WOLF3DWOLF3D.EXEcd..@echo on
Can anyone tell me why DOSBox is losing focus constantly? I've never run into this issue before.
