First post, by Arctic-Cat
Just a heads up that DOSBox 0.65 did a great job getting Lost in Time working for the most part. I unfortunately came to a part where it does lose timing with the sequence in the game. It's the point where you manage to open the strange box that you find once you get aboard the wrecked ship. Jarlath steps in and that's where it holds. You see his lips move and nothing more. The sequence does not play out with the audio track. As a result, it hangs there indefinitely. I have loaded it a few times to ensure it was simply not a synchronization error on my part. But it seems to do it at that part each time.
