Zork Anthology
First post, by webmonk
I know there are a lot of posts about Zork, and I've searched for a solution but nothing has worked yet. I apologize if I've overlooked it.
I've had the Zork games for a really long time. I don't recall details about release, version, format, etc that might identify it in a particular way if there were ones that require different solutions.
When I run any of the games from within DOSBox it does absolutely nothing. It doesn't output anything. It just seems to lock up.
If there is a solution within DOSBox, or elsewhere, I'd appreciate knowing. I really want to introduce my sons to these games as an alternative to the ones they play.
Thank You
Reply 2 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The info in the Compatibility List is provided by users and not verified in any way, so take it with a grain of salt, particularly those entries that claim a given game is broken with no information given.
That said, the Zork Anthology should work in DOSBox. Do you have the floppy or CD-ROM version? How are you installing the games? Have you tried following the 60 Seconds Guide in the guides section of the forum?
Reply 3 of 3, by webmonk
BardBun wrote on 2020-11-27, 15:40:
Zork should work no problem normally. Except for Zork 2 (1981).
I've seen that list and noticed it was present but it still doesn't work.
ripsaw8080 wrote on 2020-11-27, 22:46:
It was definitely from diskette. I'm don't think I have the diskettes anymore. I've been running it out of a directory where I've had it for many years. I've given it many times greater than the 60 seconds. Just sits there with a blinking cursor and never outputs anything.
