First post, by Kamikaze
I've got a problem with the fluence of the gamespeed. when I'm playing in the city or wherever its jucking without ending. Can I do anthing against this problem.
Reply 1 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
you are telling too little about your system and how you configured dosbox.
Water flows down the stream
Reply 2 of 16, by Kamikaze
Well I have the latest version of the dosbox. I configured my dosbox how I was told to do in the "intro" and it runs perfectly without the fu*** juckling *Fg*. I speeded up my emulation with ctrl-F12. But nothing worked. Then I tried the unlock speed with Alt-F12. With the same effect... nothing
Reply 3 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
How fast is your cpu ?
We are talking about dsa 3 right ?
Reply 4 of 16, by Kamikaze
1.87 dual core and we are talking about dsa 3! right!
Reply 5 of 16, by wd
Rank DOSBox Author
DOSBox Author
Please state the EXACT version number and your OS.
Reply 6 of 16, by Kamikaze
DOSBox-0.65 for windos xp and what is OS???
Reply 7 of 16, by wd
Rank DOSBox Author
DOSBox Author
Operating System (Betriebssystem).
Please try to set core=dynamic and cycles=auto in dosbox.conf
Who told you, and what was it exactly (was it dsa specific)?
How old is this information?
Reply 8 of 16, by Kamikaze
I got the informations from my dosbox! I made a confic like I was told in the intro of my dosbox .... and we can talk german??!??!? would make things easier! *fg*
Reply 9 of 16, by eL_PuSHeR
Das Schwarze Auge 3: Schatten Über Riva works fine for me using DOSBox 0.65ß1 final. I am playing it right now.
core=dynamic
cycles=auto
It even plays acceptably using normal core.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 10 of 16, by Kamikaze
k! what must I tell my dosbox to get core=dynamic and cycles=auto?? then I will try It again!
Reply 11 of 16, by wd
Rank DOSBox Author
DOSBox Author
Look into dosbox.conf, should be accessible through the Programme menu of XP.
Reply 12 of 16, by Kamikaze
thx...it's better now!
Reply 13 of 16, by cmw
HIer lad mal diese CVS Build von mir runter, die ist ne Woche alt (müsste eignetlich noch besser laufen als die offizielle 0.65.
http://unet.univie.ac.at/~a0501414/DOSBox.exe
Damit ersetzt du einfach die Dosbox.exe in deinem Dosbox Ordner. Mach vorher aber ein Backup der alten.
Ich hab auch ne neue Version der sdl.dll. Wahrscheinlich wirst du die brauchen.
http://unet.univie.ac.at/~a0501414/SDL.dll
Die Build dürfte sogar recht gut optimiert sein für ein Dual Core System.
Achtung: Mit dieser Dosbox.exe funktionieren folgende Dinge NICHT:
-IPX/Netzwerk (für Multiplayer in Dosbox)
-Screenshots
-Videocapture
Probierst das einfach mal aus.
Achja, und bei cycles musst dann statt Auto auf max stellen, also cycles=max
Du kannst aber auch versuchen Dosbox im Fenster laufen zu lassen und nebenher den Taskmanager und auf die CPU-Auslastung schaun, dann drückst du so lange STRG-F12 (Cycles erhöhen) bis die Auslastung so zwischen 90 und 100% ist.
Lg cmw
Reply 14 of 16, by eL_PuSHeR
It would be real kind of you if posts written in other languages than English would be translated. English is the common accepted rule here.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 15 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There are no offending words in there 😉
1+1=10
Reply 16 of 16, by eL_PuSHeR
I guess so. It's just I can't understand German. 😒
Intel i7 5960X
8 GB DDR4 (2100)
