First post, by Nova225
Specs:
Motherboard: MSI 915P combo
CPU: P4 3.0 GHz with HT
Video: ATI X850 Pro
Sound: X-Fi Xtreme music
Windows XP Home edition
Game: Elder Scrolls 2: Daggerfall, fully patched
I just cannot get this to run in DOSBox, but I have few troubles getting it to run in XP.
To start, I admit to pirating it. It ran through a basic Windows XP type of installer, and boom, the game worked. I had to seperetly scavenge for the VDMS to get the sound to work, but that's besides the point. I instaled it to run with no CD, but I do have the ISO image.
The problem with running through XP is that movement is just screwed up. Moving forward is fairly slow, and if I'm lucky I MIGHT be able to strafe and move backwards at a snails pace.
I got as far as mounting the game and running it through a batch file that directs it use two files at once, FALL.EXE and Z.CFG, just to save future typing trouble.
Whenever it gets to running, the DOS status window gives me the following error:
Exit to error: CPU:GRP5:Illegal Call 7
After looking around through different threads, I changed the CPU core from normal to simple, then full, then dynamic, and each gave a different error.
Simple: Daggerfall cannot run under Simple
Normal: Exit to error: CPU:GRP5:Illegal Call 7
Full: This just gives me a blank command screen, no cursor or anything. The DOSbox status window doesn't say anything either.
Dynamic: Same as Normal.
I'm really at a loss of what to do. Few people seem to get this error on these baords with this game...
