First post, by dnewhous
 - Member
If you run install.exe from DOSBox you get the following error message after selecting continue.
Is there anything that can be done about that?
Daniel L Newhouse
Daniel L Newhouse
[Thread moved to DOSBox subsection]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
dnewhous wrote on 2021-04-22, 02:23:Is there anything that can be done about that?
People keep replying to your posts, and you never give any indication that you are learning anything from what people are trying to tell you.
Jorpho wrote on 2021-04-22, 18:09:People keep replying to your posts, and you never give any indication that you are learning anything from what people are trying to tell you.
I have learned from this forum. Now I've run into bugs that I hope can be resolved in a future version. The version of Dungeon Hack that comes with Forgotten Realms Collection 3 would require D-70.sf2.
Daniel L Newhouse
dnewhous wrote on 2021-04-26, 20:10:I have learned from this forum. Now I've run into bugs that I hope can be resolved in a future version.
If you've learned anything it should be:
Believe it or not, DOSBox has come a long way. Now that they've added fluidsynth to DOSBox -X there's something else that can go wrong. The sound effects in Lord of the Rings were flubbed somehow, they've been fixed.
I got Eye of the Beholder to work with the Silver Collection. It's start.bat to start.
Daniel L Newhouse
