5.25 floppy
Reply 20 of 23, by bloodbat
Is it set up properly in BIOS?
It should support it, if it's connected and set up properly...try an 1.2 floppy, see if the drive works?
Reply 21 of 23, by TeaRex
And you have to set up BIOS according to your DRIVE type - not according to the type of DISK. So with a 1.2MB drive you set your BIOS to 1.2MB, even if you want to use a 360K disk.
Otherwise 1.2MB drives are compatible with 360K disks as long as you only use them to READ the disk. WRITING can give problems.
tearex
Reply 22 of 23, by Glitchologteam
I already did all those thing and it do not work. I honestly don'T understand why
I have a 1.2 floppy, I dont have 360kb floppy. I tried the bios setting to 1.2mb and and I never see the light come on the drive. The the 3.5 floppy drive work thought. This is very strange
Reply 23 of 23, by bloodbat
I assume that besides waiting for the light which could be screwed...you have tried using actual floppies with it?
