dracon wrote:Originally I had the not enough memory error but running the loadfix to remove some memory took care of that problem.
Eh - NO! You had plenty of memory. The program however got confused about all that memory and gave you a misleading error message.
dracon wrote:It ended up vista installed the programs without giving write authority to either creator or regular users.
I thought you said:
dracon wrote:I've loaded mine from the might and magic 6 CD
"loaded" - can mean different things to different people then. To me it implies something like copying the files in the simplest manner possible, preferably by hand. Next up the ladder is a word like "import" (mostly used with data that needs to be changed/converted before it can be used). And finally there is the case of "install" where some (semi)automatic process is doing magic stuff for you. Seems like you used some kind of installer...
_________________
