Reply 60 of 76, by Blinder
I'm also having a couple of issues with Privateer, a couple of which are mentioned here and I've worked through the EMS and bad IRQ issues (so, got rid of the NOEMS message and the immediate "Halted by code" problem, but I still can't get the game to load.
I have turned off all of the sound emulators in my .conf file, and set privateer's audio options to none, but the game still causes dosbox either to crash (if I do "loadfix -1 priv") or just hang (if I split the loadfix and priv up as separate commands).
It sounds like a few folks have run into this problem but I haven't been able to find a solution anywhere with the forum search.
My .conf file is as follows, this is running on an XP Pro box-
[sdl]# fullscreen -- Start dosbox directly in fullscreen.# fulldouble -- Use double buffering in fullscreen.# fullfixed -- Don't resize the screen when in fullscreen.# fullresolution -- What resolution to use for fullscreen, use together with fullfixed.# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.# hwscale -- Extra scaling of window if the output device supports hardware scaling.# autolock -- Mouse will automatically lock, if you click on the screen.# sensitiviy -- Mouse sensitivity.# waitonerror -- Wait before closing the console if dosbox has an error.# priority -- Priority levels for dosbox: lower,normal,higher,highest.# Second entry behind the comma is for when dosbox is not focused/minimized.# mapperfile -- File used to load/save the key/event mappings from.fullscreen=falsefulldouble=falsefullfixed=falsefullresolution=1280x1024output=surfacehwscale=1.00autolock=truesensitivity=100waitonerror=truepriority=higher,normalmapperfile=mapper.txt[dosbox]# language -- Select another language file.# memsize -- Amount of memory dosbox has in megabytes.# machine -- The type of machine tries to emulate:hercules,cga,tandy,vga.# captures -- Directory where things like wave,midi,screenshot get captured.language=machine=vgacaptures=capturememsize=16[render]# frameskip -- How many frames dosbox skips before drawing one.# aspect -- Do aspect correction.# scaler -- Scaler used to enlarge/enhance low resolution modes.# Supported are none,normal2x,advmame2x,advmame3x,advinterp2x,interp2x,tv2x.frameskip=0aspect=falsescaler=none[cpu]# core -- CPU Core used in emulation: simple,normal,full,dynamic.# cycles -- Amount of instructions dosbox tries to emulate each millisecond.# Setting this higher than your machine can handle is bad!# cycleup -- Amount of cycles to increase/decrease with keycombo.# cycledown Setting it lower than 100 will be a percentage.core=dynamiccycles=15000cycleup=500cycledown=500[mixer]
# nosound -- Enable silent mode, sound is still emulated though.# rate -- Mixer sample rate, setting any devices higher than this will# probably lower their sound quality.# blocksize -- Mixer block size, larger blocks might help sound stuttering# but sound will also be more lagged.# prebuffer -- How many milliseconds of data to keep on top of the blocksize.nosound=falserate=11025blocksize=2048prebuffer=10[midi]# mpu401 -- Enable MPU-401 Emulation.# intelligent -- Operate in Intelligent mode.# device -- Device that will receive the MIDI data from MPU-401.# This can be default,alsa,oss,win32,coreaudio,none.# config -- Special configuration options for the device.mpu401=falseintelligent=truedevice=defaultconfig=[sblaster]# type -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.# base,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.# mixer -- Allow the soundblaster mixer to modify the dosbox mixer.# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.# On auto the mode is determined by sblaster type.# oplrate -- Sample rate of OPL music emulation.type=nonebase=220irq=5dma=1hdma=5mixer=trueoplmode=autooplrate=11025[gus]# gus -- Enable the Gravis Ultrasound emulation.# base,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)# rate -- Sample rate of Ultrasound emulation.# ultradir -- Path to Ultrasound directory. In this directory# there should be a MIDI directory that contains# the patch files for GUS playback. Patch sets used# with Timidity should work fine.gus=falserate=22050base=240irq1=5irq2=5dma1=3dma2=3ultradir=C:\ULTRASND[speaker]# pcspeaker -- Enable PC-Speaker emulation.# pcrate -- Sample rate of the PC-Speaker sound generation.# tandyrate -- Sample rate of the Tandy 3-Voice generation.# Tandysound emulation is present if machine is set to tandy.# disney -- Enable Disney Sound Source emulation.pcspeaker=falsepcrate=22050tandyrate=22050disney=true[bios]# Nothing to setup yet![dos]# xms -- Enable XMS support.# ems -- Enable EMS support.xms=trueems=false[modem]# modem -- Enable virtual modem emulation.# comport -- COM Port modem is connected to.# listenport -- TCP Port the modem listens on for incoming connections.modem=falsecomport=2listenport=23[directserial]# directserial -- Enable serial passthrough support.# comport -- COM Port inside DOSBox.# realport -- COM Port on the Host.# defaultbps -- Default BPS.# parity -- Parity of the packets. This can be N, E or O.# bytesize -- Size of each packet. This can be 5 or 8.# stopbit -- The number of stopbits. This can be 1 or 2.directserial=falsecomport=1realport=COM1defaultbps=1200parity=Nbytesize=8stopbit=1[ipx]# ipx -- Enable ipx over UDP/IP emulation.ipx=false[autoexec]# Lines in this section will be run at startup.mount D D:\ -t cdrommount C F:\gamesc:
If anyone has any ideas I'd be very grateful, and if I manage to figure out a solution in the meantime I'll be sure to add it here.
