First post, by Fëanor-old
I have a problem with Daughter of Serpents: the graphics which are supposed to be superimposed over the backgrounds are all completely corrupted. See for instance the attached screenshot, where there's supposed to be a character standing in the middle of the room.
It is not a problem with my data files, as it occurs both with my original floppy version and the one available on HOTU.
The game's manual states that, if graphical corruption occurs, I should disable SMARTDRV. Indeed, I seem to remember that the exact same problem occurred with SMARTDRV on DOS at the time (but that was over 10 years ago, so maybe I'm making it up).
Anyway, is there a DOSBox equivalent of disabling SMARTDRV (I'm still not very clear as to what this thing was supposed to do, so I can't find the correct option to tweak)?
Thanks.
    22.23 KiB
    The character is absent, and partially replaced by random stuff
Reply 1 of 13, by HunterZ
That looks a lot like the corruption in Lord of the Rings vol 2, which was fixed in CVS. What version of DOSBox are you testing with? (in fact, please read the help guidelines and provide the requested info)
Reply 2 of 13, by Fëanor-old
Yes, of course, you're right, I should have mentioned all that. Sorry.
I'm using the latest CVS (compiled it again a few minutes ago). I'm under WinXP. Computer's a Dell laptop, with a Pentium 4 and a Radeon 9000.
The problem occurs whatever the value I set for:
  • output (surface/overlay)
    scaler, aspect ratio
    core (dynamic/normal)
    sound device used (MIDI/AdLib)
    xms/ems/umb
And I guess that's it.
Reply 3 of 13, by eL_PuSHeR
I have been playing it for 2 minutes. I haven't noticed any corruption. The interface/graphics suck big time by the way. How the hell do you travel to the museum?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 13, by Fëanor-old
Don't you see something wrong when you try taking the lift in the hotel / coming down from your room (that's the first one I noticed)?
To travel, click in the bottom-right corner (->inventory), then click on the map on the upper-right corner.
And it's not only the interface that sucks in this game... 😁
Reply 5 of 13, by eL_PuSHeR
NO. Graphics display properly for me. I have been in the hotel, across the street, museum and police station. I haven't noticed any graphic anomalies/artifacts. I am using official DOSBox 0.63
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 13, by eL_PuSHeR
Yes. I don't know if he has tried the official version too. If not, he should give it a go before using the CVS.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 8 of 13, by rcblanke
Hi there,
Strangely, for me the version from HOTU is showing graphics corruption in 0.63 as well. The guy in the bar surely is not rendered correctly.
What dosbox configuration changes did you apply, eL_PuSHeR?
Regards,
Ronald
    32.94 KiB
    This guy requires medical attention
Reply 9 of 13, by vasyl
Interesting case. Breaks all over the place but seems to work (mostly) in VirtualPC. Another thing: multivolume ARJ extracting does not work well under DOSBox, files that span multiple volumes come out corrupted due to bad date/time handling.
Reply 10 of 13, by Fëanor-old
You're right, vasyl, the problem is not with the game, but with the installer. Some files are not properly uncompressed (those spread over two discs), which causes the broken graphics. Uncompressing the thing with WinRAR or such solved the problem.
Reply 11 of 13, by vasyl
I think this particular bug was discussed before. DOSBox does not pay much attention to datestamp. Most games did not care anyway. Unfortunately, multivolume ARJ compares name and timestamp to match parts. IIRC, RAR does the same thing. This is unlikely to affect games themselves but there were quite a few installers (not to mention all kinds of "abandonware") that actually used multivolume ARJ.
Reply 12 of 13, by eL_PuSHeR
So the problem lies in the installation process. That's why it worked for me. Because I downloaded it from some site where it was repacked without installation.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 13 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
Hmm I recall I once looked into setting the date and timestamp
Have to see where I left that part of code 😀
Water flows down the stream
