First post, by madminne
Hi !
My names' s Mike and I ain' t new to DOSBox and all my favorite games are running quite well.
Except "Ski Or Die". It works allright with PC Speaker like in the old days while I couldn' t afford myself something better. But now I wanna listen to that KickAss- Music coming from Soundblaster FM.
My problem: i don' t know how to tell the game to use it (emulation in config is all set).
I tried typing "skiordie -?" and "skiordie ?" to get some advice, but there isn' t. I tried searching the net (quite long ...) and this form using the search function, but had no luck at all.
Then I tried typing "skiordie -soundblaster" , "skiordie soundblaster" , "skiordie -sblaster" , "skiordie sblaster" , "skiordie -adlib" , "skiordie adlib" , "skiordie -s" , "skiordie s" , "skiordie -a" , "skiordie a" , "skiordie -roland" and finally "skiordir roland".
Nothing worked, always shitty PC speaker.
I' m really desperate right now, cause I know EXACTLY that there' s a way to activate it (I have downloaded a sample playing the "Downhill Blitz" Track on a Yamaha OPL card, simply outstanding !).
So please if you know how to do it, tell me.
Thx for reading !
Michael
Reply 1 of 5, by rcblanke
The music from Ski or Die is indeed great!
SKI.EXE ega adlib works for me, remember to keep cycles low (3000 or so)
Regards,
Ronald
Reply 2 of 5, by madminne
Ok, i figured it out !!
I tried the command you said and it didn' t work.
Then I realized that I already tried what you said (you don' t need to type ega by the way, it starts that color mode by default), and now it became obvios to me: it' s because of a bad version of the game !
My first version was from underdogs; DON' T GET THE GAME DFROM THERE IF YOU WANT TO LISTEN TO ADLIB MUSIC !!!!
I downloaded it somewhere else (don' t know the page name, but it was an early hit in "Google"), my version does the trick typing "skiordie adlib" 😁
THX A LOT FOR YOUR HELP !!
Bye !
Reply 3 of 5, by madminne
If you want to listen to Roland MT-32 simply start the game as following:
"skiordie mt32"
It sounds shitty to me (but very funny when listening to church bells instead of electric guitars 🤣 )
So Long !
Reply 4 of 5, by DosFreak
Did you report this to Underdogs? If you experienced this issue then likely someone else in the future will experience too. Best to nip it in the bud if possible. So if you could please contact the Underdogs people and tell them about it.
I don't really frequent their site but they should have a contact email address somewhere on their site and if they don't just post in the forums.
Make your games work offline
Reply 5 of 5, by rcblanke
madminne wrote:
If you want to listen to Roland MT-32 simply start the game as following: […]
"skiordie mt32"
So Long !
Well, I have to say the MT32 music is not too bad using Munt, but SODs' adlib music is very groovy indeed. Glad you figured out how to get it working.
Regards,
Ronald
