Prince of Persia 2 sound
First post, by boxrun
Forgive me if I'm missing something obvious.
I cant get Prince of Persia 2 to work with sound properly
When the game is run it gives a warning "digital sounds will not be played because there is no extended or expanded memory available"
what tweaks might be needed in dosbox.conf over the default 0.65
Reply 1 of 1, by wd
Rank DOSBox Author
DOSBox Author
Try some different settings for ems/xms in dosbox.conf, like both
on or both off. Also see if lowering the cycles helps.
