Season of Sakura Help
First post, by chewyman
Hi, I'm new to these forums, after a friend recently recommended I download DOSBox. I'm computer illiterate and have no idea what everything means but I'm learning. I read the guide and did what it said without any luck. I also read the notice for help requests but I couldn't answer any of the questions about my computer other than that I use Windows XP Home Edition. There have been other threads concerning this game, and I have followed the advice in them, again without any luck.
This is what I have done so far to try and get Season of Sakura to work:
1. copy and paste the SK_01.M file into both the GRA and OVL folders as well as leaving it in the original main folder just in case (the zip of the game came with a notepad document that said "SEASON OF SAKURA fix
1.Good, you've unzip the file.
2.Put this file in the game's directory [I don't know what that is]
3.Check for SK_01.M with "dir sk_01.*"
4.If exist then ----> Enjoy...
fixed by Edsa M.A (menduk1@idola.net.id)"
2. created a folder called 'temp' with the file 'CDATA.000' in it, as was recommended (I think) in another SoS thread (I'm not sure as I didn't understand the explanation)
3. in DOSBox I have then typed the following code:
- mount d d:\ -t cdrom -ioctl
- mount h h:\torrents\games\collection\season_of_sakura
- set path=h:\temp [Once again, no idea what this does but I think it was recommended in another thread]
- h:
- saku_d\saku-fm.bat
Reply 1 of 6, by chewyman
The following are the notifications I get:
- When I type saku-fm.bat in DOSBox some writing flashes and disappears before I can see it then a new page appears that says "Music Driver P.M.D. for IBMPC/OPL Version 4.6a
Copyright (C)1989,Oct.23th 1993 by M.Kajihara(KAJA).
Removed from Memory."
- If I double click on the actual file 'saku-fm.bat' windows cmd appears. It says "H:\torrents\games\collection\season_of_sakura\saku_d>echo off [What is an echo in DOS terms mean?]
The system cannot find the path specified.
Copyright <C>1989,Oct.23th 1993 by M.Kajihara,KAJA>." cmd.exe then proceeds to take up all of my RAM until I close it, which actually doing nothing.
The following is a complete list of the files on the SoS directory if it helps make things a little clearer.
H:\torrents\games\collection\season_of_sakura:
saku_d (folder)
temp (folder that I created)
a whole lot of character's names followed by .000
H:\torrents\games\collection\season_of_sakura\temp:
CDATA.000 (I copied this into here myself)
H:\torrents\games\collection\season_of_sakura\saku_d:
GRA (folder, I copied SK_01.M into here)
OVL (folder, I also copied SK_01.M into here)
AUTORUN
CDATA.000
CDM
FILE
JAST
MAIN
PMDIBM
SAKU
SAKU-CD
SAKU-FM
SK_01.M (up to SK_33.M)
T_ADV1
I don't think the GRA and OVL folders are going to be important, but if you'd like I can write down what is in those files as well on request.
Another thing that, although not recommended, I have tried is clicking on the SAKU-CD file. The game then loads (I assume) but closes straight away and I get an error box that says "H:\torrent\games\collec~1\season~2\saku_d\saku-cd.pif
Invalid program file name, please check your pif file. Choose 'close' to terminate the application"
Please help me!
Reply 3 of 6, by Yaan
How did you get it to work? My Season Of Sakura game had this kind of problem too -- I just don't know how to fix it!!
BTW, did you download this game? If you do, can you give me the link where you download this file? I don't think mine (the Season of Sakura game) is going to last longer in my PC...
Many thanks!
Computer Illiterate -- I don't understand my PC!
