DOSBox, DPMI & Quake
First post, by rautamiekka
I got Quake running with DOSBox after had been altered the properties of Quake.exe using other site but it was running VEEEEEEEEEEEEEEEEEEERY slow, regardless of the amount of CPU cycles. I though that if I delete the whole Quake folder, I'd get it running at normal speed in DOSBox, however, this caused DOSBox to complain about DPMI. I went back to the exe's properties and set the same settings, but didn't add that altered autoexec and config.nt.
What to do ? I'm desperate ... 😖
Reply 1 of 35, by wd
Rank DOSBox Author
DOSBox Author
About Quake being slow under dosbox: what version are you using,
and under what operating system?
About dpmi: dosbox doesn't need any dpmi host, but the game (Quake)
needs it. Search for the csdpmi (cwsdpmi) package on the net.
Reply 2 of 35, by rautamiekka
Quake 1.01 unpatched
WinXP Pro SP2
Reply 3 of 35, by DosFreak
Download DarkPlaces and use that for Quake.
Quake 1.01 is really old. Last version for Quake was v1.08 or v1.09 IIRC. The official demo and full versions of Quake come with CWSDPMI .....
Make your games work offline
Reply 4 of 35, by rautamiekka
If that's the case I can patch it using 1.06 or 1.08, I have both.
Reply 5 of 35, by rautamiekka
I tested on other computer: no effect in speed ... And that darkplaces-thingy's site is very weird and it doesn't allow me to download from there ...
Reply 6 of 35, by leileilol
Quake v1.01 isn't slow. It works fine here. Use dynamic core and auto cycles.
v1.08 is the version supplied by the mission packs and 1.09 is the version of Windows/Linux ports.
long live PCem
FUCK "AI"
Reply 7 of 35, by rautamiekka
One problem: I don't know anything about that dynamic core ...
Reply 9 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
to dynamic
auto doesn't exist yet
Water flows down the stream
Reply 10 of 35, by rautamiekka
Let's try ... By the way, is there a way to make auto cycle enabled via the conf ?
EDIT: found that yes, it can. I put it to auto
Reply 11 of 35, by rautamiekka
OH THANK YOU ! The game runs just like on a DOS-computer ! Perfect 😀
Reply 12 of 35, by rautamiekka
But, however, I don't hear any sounds
Reply 13 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
start with low cycles (3000)
and increase them when you reach the menu(ctrl-f12)
Reply 14 of 35, by rautamiekka
That doesn't work, tried before
Reply 15 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
did you run the setup of the game ?
Reply 16 of 35, by rautamiekka
umm ... Quake1 does not have any, and I installed the game normally from windows. Is that the cause ? But I installed the update from DOSbox
Reply 17 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
in my quake dir there is a setup.cfg
maybe remove that one and see if it works
game works here with sound effects. (not music, but that is stated in quake itself specificly)
Reply 18 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
and check the idl directory as well
also some configfiles
Reply 19 of 35, by rautamiekka
This is what Quake says:
Sound Initialization
Sound Card is UltraSound
Sound sampling rate: 19293
MSCDEX not loaded, music is disabled. Use "-nocdaudio" if you wish to avoid this message in the future. See README.TXT for help.
Press a key.
Version is 1.06 ...
