First post, by InPhets
Hi, im new here and with Dosbox.
So the question is really simple.
How do I launch a game from dosbox? Example Settlers2 gold.
Take all from the beginning when u explain.
Tnx 😀
Reply 1 of 26, by eL_PuSHeR
Welcome to the forums.
Read the FAQ/Guidelines located at the appropiate section(s) in the forum.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 26, by wd
Rank DOSBox Author
DOSBox Author
Well those are the easy explanations, you don't want to read the others 😉
Basically they guide you step by step, if you don't understand some step
feel free to ask, same if some step simply doesn't work for you.
Reply 10 of 26, by wd
Rank DOSBox Author
DOSBox Author
Ok, that's fine so far.
Do you remember dos commands? Type "D:" to change to the
d drive (which you just mounted), then type "dir" to see what
files are there. Those should match what is in your
D:\Spill\Settlers2\Settlers2gold
directory.
Reply 12 of 26, by eL_PuSHeR
You need some crash course in ms-dos commands mate.
type d: to change to d drive
then type in the command used for starting the game (bat, com, exe are all executable extensions).
E.G. s2.exe or play.bat
Intel i7 5960X
8 GB DDR4 (2100)
Reply 17 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
what is the size of s2.exe ?
I thought you started settlers2 usign a different executable though
Water flows down the stream
