First post, by mforcer
i'm kinda new to the community ^^" using a regular 2,0 ghz pc
trying to play "wings of fury" with the dosbox emulator, the problem is
when i start the game in windows, it's just going waaaaay to fast, so i hoped dosbox would solve this problem , but when i start wings in dosbox, i see the intro & menu but when i'm about to start the mission, it kicks me back to dos, with a message thank you for playing or buying bla bla bla Oo"
i've tried messing with the configuration files and the memory fixes, but after doing that, the game won't start at all
So my question is, how can i get the game to work, or is there a simple solution to make windows play the game reeeeeeally slow Oo" i prefer a dosbox solution though ^^" it's fun
~thanks in advance~ ^_-
Reply 1 of 10, by MiniMax
Rank Moderator
Moderator
Did you re-install the game through DOSBox?
_________________
Reply 2 of 10, by mforcer
i've tried, but it keeps asking for disk b =/ which i don't have..
but the version i've got is already unpacked, it's one of those abandonware .zip-ies with the entire game, it runs in windows though =/
Reply 3 of 10, by MiniMax
Rank Moderator
Moderator
I have never used it myself, but I have heard of a program called moslow that can be used in Windows to slow down a game. VDMSound comes with a program called speedset. Maybe that will help?
_________________
Reply 4 of 10, by mforcer
I've tried the moslow, but it didn't work probably because it was a trial version or something =S
I've tried speedset , and it worked to a certain amount,.
i could slow it down to -45 but if i go higher than that, the game crashes or give somekind of an out of memory error
i've added the game, maybe you can play it 😄"
[and i removed it]
Reply 6 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It certainly does not. Who knows what those abandonware people messed up... 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 10, by eL_PuSHeR
Solution seems easy. Just run WOFC.EXE, WOFE.EXE or WOFT.EXE to run the game, depending you want CGA, EGA or TANDY. The original loader (DASHC.PES) doesn't work using DOSBox.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 8 of 10, by mforcer
no , i've tried that, didn't work -_-" i get kicked back to dosbox again just when the mission is about to start.
as far as i'm concerned it's the original game =/
are there any other solutions? perhaps a combination of speedset and dosbox or something , i don't know =/
Reply 9 of 10, by wd
Rank DOSBox Author
DOSBox Author
It doesn't matter how far it's your concern that it's the original game.
Buy it or dig it up from your disks, and THEN report back.
Reply 10 of 10, by whocrazy
I had a similar problem with abandoned places (no, not the website, the game)
The game wouldn't start, it just kept on jumping back to dos, then I discovered whoever had put the package together had gotten the files all in the wrong location, they were supposed to be in a sub directory called data
Maybe the latest cvs build would help
Some other things to try:
try slowing the emulation system down with ctrl f11
Make sure you have the right machine being emulated, IE: cga or vga.
IT's never a good idea to have your dosbox start up in CGA mode and then try to run a game meant for VGA
try changing the sound emulation IE sb16, sbpro2 sb1, sbpro1 etc
Hope this helps
