Command and Conquer
First post, by icemann
Hey all
My only problem with running dosbox with Command and Conquer (dos version) is inregards to unit number assigning (as in assigning x number of units to a number key by doing the ctrl+number key) as the ctrl key is used for dosbox functions (increasing cpu cycles etc etc), and so if I currently attempt to assign units to a number key nothing happens besides a flash of the screen.
I recall being able to do the function just fine in earlier versions. Though those didn`t come with the dosbox menus and C&C ran slower in those versions.
Using CVS version.
Two stones, two crosses, the rest is just icing. - 7th Guest
Reply 2 of 2, by icemann
Thankyou that fixed the problem 😀
