First post, by Vaelor
- Newbie
Hi guys,
As per this thread, I recently upgrading my version of DOSBox from v0.63 to v0.65 to get Leisure Suit Larry 7 working. It solved my problem, and that game now works perfectly.
However, the other game I'd recently needed to use DOSBox for, Fury of the Furries, which was working perfectly under v0.63, now does NOT work properly since the upgrade!
The game freezes completely a few seconds into the intro sequence. The music keeps playing fine but nothing happens visually.
If I bypass the intro (which is a seperate EXE to the game) and just run the game, it starts up fine, the menus are fine and smooth and everything's great until I actually start up a level, at which point the game grinds completely down, rock bottom FPS, laggy music, flickering graphics - pretty much how the game runs without using DOSBox at all.
It worked fine under v0.63 though, and I haven't changed anything. What do I do now??
Vaelor's Keep
