First post, by fxtech
Has anyone gotten Ultralaunch (DOOM, DOOM2, Heretic launcher) to work under DOSBox? Ultralaunch runs, but when I try to launch DOOM it acts as though I played DOOM and comes right back to the Ultralaunch screen. I'd really like to get this app working as it makes setting up IPX games and managing wads a breeze.
DOOM works great on DOSBox! I've even been able to get the IPXNET working. Fantastic program!
Trev
Reply 1 of 18, by fxtech
Here is the last release of UltraLaunch if someone wants to give it a try. I have done a little investigating. Looks like UL creates a batch file when you launch DOOM called ULRUN.BAT and it looks like this:
@ECHO OFF
C:
CD C:\GAMES\DOOM1_9
ECHO | DOOM.EXE @C:\GAMES\UL\UL.DAT\RESPONSE.UL
C:
CD C:\GAMES\UL
UL.BAT /1 /RETURN
My guess is that the 4th line is the problem. Like I said, this is an auto-generated batch file that UL creates when launched based on the selected parameters. UL also creates a file called ULRETURN.DAT. Not sure what the function of this file is.
Any work arounds???
    UL204.zip
    178.96 KiB
    363 downloads
    The final release of UltraLaunch - V2.04 - direct from the Author...
Reply 2 of 18, by IIGS_User
I assume you meant this as the fourth line? I think not that this line is the problem.
ECHO is just a screen replay w/o some function remaining.
Klimawandel.
Reply 10 of 18, by MiniMax
Rank Moderator
Moderator
The @C:\GAMES\..... stuff looks like an instruction to DOOM.EXE to read some parameters or configuration options from the RESPONSE.UL file.
Somewhere along the lines, I guess DOOM.EXE is waiting for someone to press ENTER. Piping an empty string with ECHO into the pipe, gives it that ENTER/NEWLINE it is waiting for.
Unless this file is re-created every time, you can try
1) Remove the "ECHO |" and try to press ENTER yourself when DOOM seems to have stalled.
2) Create an empty txt file and use redirection instead of piping:
DOOM.EXE @C:\GAMES\UL\UL.DAT\RESPONSE.UL < EMPTY.TXT
_________________
Reply 11 of 18, by fxtech
Yea, I thought about trying something like this, but the problem is that the files are created upon launching DOOM and deleted after exiting. I was able to grab the files by running UL out of XP and copying the files to the desktop.
I don't know if any of you have ever used UltraLaunch, but it was by far the best front end for DOOM, DOOMII, and Heretic. You have access to all aspects of the command line functions. Keith Cohen was the Author, and I have contacted him. He is looking for the source code. It was written in Turbo Pascal 7. If he finds the source, I may be able to modify it to be DOSBox friendly.
I know that there were other front ends (I used to have most of them), but they may have the same problem. Anyone else have one working?
Trev
Reply 12 of 18, by Qbix
Rank DOSBox Author
DOSBox Author
echo | for the enter.
so basicly this command can be split up into 2 parts:
1 echo >tempfile
2 doom @.... <tempfile.
An interresting test (as far as I'm concerned) is what will happen if the disk is write-protected (or all disks are write protected) (this is for on how to implement this piping as > and < are allready supported)
Water flows down the stream
Reply 13 of 18, by MiniMax
Rank Moderator
Moderator
While it would be nice if the DOSBox command line had all the features of the original COMMAND.COM so all BAT-installers and menu-systems etc would work, you should be able to create an even nicer launcher with the help of the graphical DOSBox frontends DBGL and DOG.
_________________
Reply 14 of 18, by MiniMax
Rank Moderator
Moderator
Maybe
DOOM.EXE @C:\GAMES\UL\UL.DAT\RESPONSE.UL < NUL:
would do?
_________________
Reply 15 of 18, by ConqSoft
Hello all. I'm the author of UltraLaunch. Just ran across this old thread and wanted to post a link to the source code for any that wanted to mess around with it:
http://www.conqsoft.com/misc/ulsource.zip
Reply 16 of 18, by rfnagel
BTW, here's a patch that I released for the "Eternal Shell" that came with Team Eternal's "Eternal DOOM"... same sort of problem, fixed with the EShell patch -> Eternal Doom Shell .
That pipe "|" is a little undocumented thing that in DOOM will make it so that you don't have to press the enter key when other addon WADs are loaded in at startup. Normally when running the game with an addon WAD, the startup screen will halt with the message "This copy of DOOM has been modified" (or something like that), and "Press enter to continue".
The pipe will make it so you don't have to press enter (the game simply goes through the startup screen as usual), as Eternal DOOM's Eternal Shell launcher adds a lot of things to the game at startup.
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 17 of 18, by DrMedWurst
ConqSoft wrote on 2011-03-20, 23:28:
I'm sorry to dig up such an old thread but I'm guessing that none of you have archived/saved the source code?
The only versions of Ultralaunch I can find are all limited in their features, e.g. only 20 wads can be loaded and they are limited to a single database
64K RAM SYSTEM 38911 BASIC BYTES FREE
Reply 18 of 18, by DrMedWurst
Two CDs called Total Ruin and Total Ruin 2 each contain a registered copy of Ultralaunch.
Total Ruin = v1.04
Total Ruin 2 = v2.04
In this case, a simple copy of the installation data will do. You can also open ULINST.CS from the Total Ruin 2 CD with 7zip and extract the UL.KEY file from there.
You can use this key file e.g. with the 2.04 and 2.05 version which are attached in this thread. (The 2.05 version has no improvements to the 2.04 version)
I have not provided the key file because I am not sure if I am allowed to but if someone is interested he should now know where to find it
But i am still interested in the source code. so if someone has archived the above zip i would appreciate it to be notified 😀
    ul205.zip
    178.04 KiB
    47 downloads
