Reply 20 of 43, by Patrick benatar
- Newbie
please help, forums are endless, threads, topics, i have read dosbox documentation, copied some of your responses, kicked, screamed and cried etc....
I taught myself to use dosbox a couple of years ago to a certain level of satisfaction, and I had thousands of games running on xp.
I just got a laptop with far more powerful specs than my old damaged one that is running on Vista.
I simply copied the dosbox file from xp program files and pasted it into my vista program files and it works just fine using my prefered method of dragging .exe icons to the dosbox .exe without needing to be re installed in vista.
** The problem is trying to run programs in fullscreen in vista, they work fine in window, then become too slow and jerky when expanded.
I have played with my .conf file, i have tried dynamic, max, auto, setting my own aspect ratio, and making it auto, adjusting for aspect conversion, setting memory to 16 and then to 32, I have tried different combinations of the above, and have not found a setting that makes games acceptably playable.
The frustrating thing is that a european site offers some of it's games in prepackaged self installing folders with dosbox configurations that mount an .iso within each game folder by the user merely clicking an .exe icon, and these work fine.
I tried copying the .conf files in these folders for the .conf file in my universal dosbox file and I can't replicate the same conditions.
Also, i cannot type a goddamn frigging \ in dos prompts the \ key does nothing, and I can't find the key/key combo that works to produce a \ in the prompt.
Help me obi wan kenobi you're my only hope!
