First post, by yanivsag
Hi,
I've got an old Dos accounting application working almost perfectly on Dosbox. Almost, because I'm having a problem accessing the floppy disk (real or a virtual one) using that app. I can echo to a txt file through the dosbox command line, but when the app has problem writing to a floppy. it says the diskette is not writable.
Any ideas?
Did happen to anyone on other apps?
thanks
yaniv
Reply 9 of 14, by yanivsag
It's odd, but it's also very old...
They have a "backup" mechanism which only works with diskettes. furthermore, the IRS sometimes asks for this floppy to keep track.
I've installed freedos in the past on ms virtual pc. is it problematic under dosbox?
what to do after i install it?
Reply 10 of 14, by wd
Rank DOSBox Author
DOSBox Author
There should be some diskimage tutorial at the guides forum.
After installation the application has full int13 access (lowlevel) to some
mounted floppy image. This should be enough for this type of backup.
The drawback is that, once booted freedos, you loose the regular mounts.
