First post, by Wrr
I'm trying to get X-com 1/2 to run in dos in order to stop the weird graphics errors (see image below) When I try to run X-com 1/2 It says "This program cannot run in DOS mode" I've been unable to figure out why this is so and unable to find any solutions
[/url]
Reply 1 of 8, by wildweasel
If your copy of X-COM is the "Gold" edition, then I recall that those weren't actually DOS programs - they're Windows ports, albeit very shoddy and unstable ones.
Reply 2 of 8, by DosFreak
You need to reduce hardware acceleration for video or you can find the Xcom patch that fixes this problem. I don't have a link handy at the moment to the patch.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 8, by njaydg
You should follow DosFreak's advice, and get the patch here.
Honestly, the DOS version (CD-ROM to be precise) of X-COM would cause you far less trouble (i've tried both myself), but the final call it's up to you...
Hope it helps.
Reply 8 of 8, by Wrr
Ooooh, I see it now, It's linked to in the faq but not from the downloads page (where I was looking for it)
Found it, put it in folder.
"Patch code timed out"
😐 Comeon
EDIT-
Used the "Xcom Tftd" Fixed .exe file.
http://www.xcomufo.com/forums/index.php?showtopic=4425
