First post, by DosFreak
http://forums.steampowered.com/forums/showthr … ighlight=dosbox
Started up my PC today and wanted to play Commander Keen > again this damn problem, but I can't remove the exit instructions, because they ARE removed -.-
So, as it seems, it works only one time Ò_Ó
EDIT: OMFG thats really strange. I removed my gamepad (cause it was removed yesterday when it worked too) > IT WORKS (and WITH the exit instructions). So, I put the pad back and looked at the Command window while starting the game > Result: it terminates while loading the gamepad in DosBox
Make your games work offline
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
yes, known bug.
joysticktype=none fixes it, but then you don't have a joystick either 😀
Will be fixed in the next version of dosbox
Water flows down the stream
