Star Fighter 3000
First post, by alienjon
Just so this is clear, the game I'm looking at is the 3D0 version of Star Fighter, titled Star Fighter 3000 (released in 1996).
The game installs and starts just fine (I installed it with the 'Full Installation' option so the CD shouldn't be required but I have it in the drive anyway)
Now there are 3 intro movies which play followed by the loading screen. The main menu should load afterwards, but instead the game crashes back to dosbox with the error:
Star Fighter allocated a maximum of 5121370 bytes of memory.
Having done a search through the games list (where the game wasn't even listed, but I added it, this forum (where I couldn't even find the game) in any thread, and a google search, the google search proved helpful in that there were some suggestions to try changing the soundblaster from sb16 to sbpro (I didn't think this would do it as the sound plays just fine in the movies) as well as disabling either XMS or EMS memory (or both) - XMS needs to be enabled, but the game starts regardless of the state of the EMS memory - and changing the memsize from my default of '32' to a maximum of 63 or a minimum of 1 (I also tried several numbers in between)
The long and short of it is that this game just doesn't seem to want to run but I don't think it's dosbox's fault as much as it needs a properly tweaked dosbox.conf file. Any thoughts on this matter?
Reply 3 of 15, by Jorpho
If you're trying to run the version from Home of the Underdogs, it can be pretty picky about its installation. Nonetheless, it can be made to run: http://www.the-underdogs.info/forum/viewtopic.php?t=46561 .
Or are you speaking of something else entirely?
Reply 5 of 15, by Jorpho
Really? That's quite impressive, considering how rare the game is, supposedly.
Does the install still create a directory named KRISALIS.CD in whatever directory you mount as C: ?
Does the demo at http://www.3dgamers.com/games/starfighter/downloads/ work? Maybe its readme has some insights. (That is, maybe you need a C:\GAMES directory too.)
I suppose you could also try the 3DFX patch from that site and see if that has any effect.
Reply 7 of 15, by alienjon
OK. Well, the good news is that I think I've figured it out, the bad news is that it still isn't working the way I'd like it to.
As it was with the link from the underdogs forum says above, the demo works on my computer. Downloading the underdogs version works but only if I create the KRISALIS.CD directory and put the SF3000v1.08 configuration file in it (which for some reason wasn't created by INSTALL.EXE as it was supposed to be) but luckily I had it from my CD installation (and for anyone else who might be reading this, grab the demo version and change the version number on it to match 1.08 and that should work as well)
Now, while the Underdogs version does work, it does not play movies or music (which makes sense because it was probably fixed so that it didn't need the CD anymore)
That being said, I read somewhere that the only copy protection for the game is that the game requires the CD to be in the drive when you play regardless of the installation type (so full installations will require the cd just as much as the minimal does) This makes me think that the reason my original CD version of the game doesn't work is because it needs the CD and can't read the protection off of it for some reason (it did used to work, by the way, and yes this is an original disc, nothing copied) I did create an ISO of the CD but there was no change there either.
The end result here is that the game will work, albeit without music or videos, when using the Underdog version. I would still prefer to get the original cd install to work, but that may not happen if no one can figure out the cd protection bit.
Any thoughts anyone?
Reply 8 of 15, by Jorpho
Have you tried using the debug version of DOSBox to determine what files your version of Starfighter is trying to access? (ykhwong's CVS build from here works.)
The copy protection also might be a simple matter of the game trying to read the CD's volume label. Try using the -label switch with mount, and specify whatever name Windows Explorer gives for the CD.
(Is Star Fighter one word or two...?)
Reply 9 of 15, by alienjon
Being a Gentooer the debug version of dosbox is rather easy and simply requires a quick emerge. The output, while rather interesting, unfortunately doesn't really tell me anything. I've looked (and logged) the information that is put out just as it crashes but nothing seems to be informative, (in that there isn't anything that looks like errors or otherwise shouldn't be the way it is)
I also tried setting the CD label but also to no avail. It looks like the copy protection (if that is indeed the problem) is not effected by the CD label (or at least from what I can tell from the regular and debug output)
Just to show it with this message, here's the debug lines that came up just before the game crashes:
[35d[M[47d 245451474: MISC:MSCDEX: INT 2F 1500 BX= 0000 CX=000A
[35d[M[47d 245453853: MISC:MSCDEX: INT 2F 1510 BX= 000C CX=0003
[35d[M[47d 245453853: MISC:MSCDEX: Driver Function 85
[35d[M[47d 245453853: MISC:MSCDEX: Status : 0100
[35d[M[47d 245454177: MISC:MSCDEX: INT 2F 1510 BX= 000A CX=0003
[35d[M[47d 245454177: MISC:MSCDEX: Driver Function 03
[35d[M[47d 245454177: MISC:MSCDEX: IOCTL INPUT Subfunction 0A
[35d[M[47d 245454177: MISC:MSCDEX: Status : 0100
[35d[M[47d 245454513: MISC:MSCDEX: INT 2F 1510 BX= 000A CX=0003
[35d[M[47d 245454513: MISC:MSCDEX: Driver Function 03
[35d[M[47d 245454513: MISC:MSCDEX: IOCTL INPUT Subfunction 0B
[35d[M[47d 245454513: MISC:MSCDEX: Status : 0100
[35d[M[47d 245454934: MISC:MSCDEX: INT 2F 1510 BX= 000C CX=0003
[35d[M[47d 245454934: MISC:MSCDEX: Driver Function 85
[35d[M[47d 245454934: MISC:MSCDEX: Status : 0100
[35d[M[47d 245456171: PIC:0 mask 79
[35d[M[47d 245456179: PIT:PIT 0 Timer at 120.00 Hz mode 3
[35d[M[47d 245456183: PIC:0 mask 78
[35d[M[47d 245456225: PIC:0 mask 79
[35d[M[47d 245456469: PIC:0 mask 78
[35d[M[47d 245456562: PIC:0 mask F8
[35d[M[47d 245456573: SBLASTER:DMA masked,stopping output, left 1761
[35d[M[47d 245456643: PIC:0 mask F8
[35d[M[47d 245460784: DOSMISC:DOS:Multiplex Unhandled call 1600
[35d[M[47d 245461094: DOSMISC:DOS:Multiplex Unhandled call 1600
[35d[M[47d 245466676: PIC:0 mask F9
[35d[M[47d 245466705: PIC:0 mask F9
[35d[M[47d 245469780: PIT:PIT 0 Timer set without new control word
[35d[M[47d 245469780: PIT:PIT 0 Timer at 18.21 Hz mode 3
[35d[M[47d 245469784: PIC:0 mask F8
[35d[M[47d 245469813: PIC:0 mask F8
[35d[M[47d 245473843: INT10:Set Video Mode 3
[35d[M[47d 245473843: VGA:Blinking 8
[35d[M[47d 245687938: VGA:h total 100 end 80 blank (80/98) retrace (85/97)
[35d[M[47d 245687938: VGA:v total 449 end 400 blank (406/441) retrace (412/414)
[35d[M[47d 245687938: VGA:Width 640, Height 400, fps 70.086594
[35d[M[47d 245687938: VGA:normal width, normal height aspect 1.000000
[35d[M[47d 245730742: VGAMISC:Parts left: 1
[35d[M[47d 255151076: EXEC:Parsing command line: exit
[35d[M[47d 255151076: SBLASTER:DSP:Reset
[?12l[?25hc
As a last note, regarding proper formation of the name, I've seen it listed as both Star Fighter 3000 and Starfighter 3000 and while the readme that is on the CD just says 'Star Fighter', I want to say that in most places I see it as one word: 'Starfighter 3000'
Reply 12 of 15, by Miki Maus
I got underdogs version to work, even with 3dfx patch from 3DGamers (running with /no3dfx switch when 3dfx is not present) in DOSBox, WinXP (with VDMSound, DOS32A, with dgVesa to run in a window 😎 ) and working 3dfx on old Win98SE machine.
So I would suggest to try to run it with 3dfx patch from 3DGamers (with /no3dfx).
I'll attach it to this message, as I don't see many places where you can get that patch. 😀
    star3dfx.zip
    468.56 KiB
    910 downloads
Reply 13 of 15, by alienjon
I got underdogs version to work, even with 3dfx patch from 3DGamers (running with /no3dfx switch when 3dfx is not present) in DOSBox, WinXP (with VDMSound, DOS32A, with dgVesa to run in a window Cool ) and working 3dfx on old Win98SE machine.
I'll attach it to this message, as I don't see many places where you can get that patch. Happy
As I mentioned in an earlier comment, I did happen to get the Underdogs version to work, but there aren't any intro movies (not that I care a whole lot about these, but it'll be hard to tell if there'll be any other movies either) and there isn't any CD music (whether the CD is in the drive or not). That being said, I have tried both the 3dfx patch with both the Underdog version of the game and the CD version and there was no change (improvement or otherwise) in either. I did try the /no3dfx parameter, but still no change. As the game exits the same way regardless of whether the CD is in the drive or not, I'm thinking that it's a copywrite protection issue somehow.
Reply 14 of 15, by SavageMind
I'm using DBGL 0.65. I saw the settings you were talking about. When ever I start the game it just goes to a black screen and sits there. I'm not sure how to set VDMSound, DOS32A, and dgVesa. I still play this on the saturn and I really want to play it on RISC OS again but I don't want to pay 21 bucks to play a 12yr old game. Any help would be great.
We herd sheep, we drive cattle, we lead people. Lead me, follow me, or get out of my way.
Gen George S. Patton
Reply 15 of 15, by ChrisR3tro
Hi all!
@alienjon: I get the same problem with the game which you got, except I didn't use DOSBox, but my retro DOS machine. Here are the specs:
400 Mhz AMD K6-III
64 megs of RAM
DOS 6.22
Original CD version of the game
I have tried himem.sys, himem+emm386 and qemm, none of which worked. Soundcard selection doesn't seem to have any effect. Also, I can reconstruct the problem with DOSBox 0.73.
This is really odd and I somehow doubt that it is memory related, because the game makes use of a fairly new version of the dos4gw extender (2.00). Actually I don't even think it's a kind of copy protection. Detection of the disk usually starts before any part of the game is loaded. I might be wrong, but otherwise I am totally clueless here.
locutus
for more Retro-related tidbits follow me on X under @ChrisR3tro.
