First post, by vogon player
I don't imagine that there are many people using Breadbox Ensemble under DOSBox, so if no one knows of a solution to this problem it will be perfectly understandable.
I have installed Breadbox Ensemble 4.010 and it runs fine under DOSBox 0.72, but I have noticed that if I try to launch any DOS programs or batch files from within Ensemble, I always receive the following error message:
An error occurred during this operation
Please try again
Error Code: FM-27
I'm just wondering if any other Breadbox Ensemble users may have encountered this problem before. If so, have you been able to find a solution? Otherwise, the native Ensemble applications appear to be functioning OK.
Searches for this error message have not provided any additional tips beyond trying to launch the program again.
It may even be that DOS applications won't launch properly from within Ensemble when it is running inside DOSBox... but I can't say for sure whether this is the case or not. I really wouldn't be surprised to hear that this is the case however...
