Sorry about that. My Trek2 configuration file which for some reason indicates it's a Microsoft Outlook Outlook Configuration file indicates the following:
src=D:\
dst=C:\intrplay\trek2\
install=D:\
resource=D:\idata\
video=MCGA
input=MCGA
music=A002
music_io=220
sound=E000
sound_io=220
sound_irq=7
sound_dma=1
setup=0
talktype=0
My System info: Pentium D 3.00 GHZ
hard drive drive C: 228 GB
RAM: 2 GB
Windows XP Media Center
I would appreciate any help. Not sure if the problem is caused by some of my file in the intrplay directory might be read-only which should not be.
I have discovered that games can be saved if the entire C drive is mounted. Is that safe to do? I thought that might cause problems so mounting the directory and subfolders where the game is stored was the right thing to do. c Thanks for the help.
