First post, by whocrazy
Hello there. There's this game I am trying to run, it's called drone, no it does not run from a cd, it is a simple text based game written in q basic.
Anyhow, when I try to run the game, I get this error in the console.
Warning: file d:\drone\CON exists and failed to open in write mode.
Please Remove write-protection.
What gives?
Here are the autoexec.bat lines at the end of dosbox.conf
mount c c:\
mount d d:\
I then cd to drone (cd\d:\drone)
then type drone
I then get this error
path/file access error in line no line number in module drone at address 0f02:0117
Hit any key to return to system.
Ok guys, it's over to you.
