First post, by ZZZ
The Case of the Cautious Condor (PC version of course) gives me a crash when I try to run it with following message: "Fatal signal: Segmentation Fault (SDL Parachute Deployed)". I use the latest DOSBox version and tried several configurations.
Reply 5 of 7, by catchaserguns
Unfortunately since you got the game from an abandonware site we cannot be much help. We don't support abandonware on this site. The Good Old Days has a Forum and are willing to answer any problem. Good Luck.
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
wd wanted to know which version of DOSBox you are using and which OS you have.
(to be sure that latest is really the latest)
You might want to try dosbox 0.65. if 0.72 doesn't work.
The whole 0.7x serie is currently comparable when it comes to compatibility.
Water flows down the stream
