First post, by Chuckles8732
Hi,
I am trying to use DOSBox to run the old 1994 floppy version of Star Wars TIE Fighter. I can get the install program to run, and I set my cpu to dynamic and my cycles to max in order for the installer to think my machine is "medium" rather than "slow". It starts installing fine, but when I have to swap to disk 2(of 5), i can physically swap fine, but the program won't continue, maybe thinking that disk 1 is still in there? I tried making images of all the floppies, but then I found out floppy image swapping isn't supported 😵 . Since the first thread in the forum asked, my system is:
ECS P4VXASD2+ Motherboard
1.7 ghz celeron
300-something megabytes of I think SDRAM
ati radeon 7000 series with 32 mb vram running on omega drivers
vinyl ac'97 audio
Windows XP
If anyone wanting to help needs more info, just reply and I'll give it to you if I can.
Thanks in advance for any help!
