First post, by t0mme
Hi everybody,
I bought the newest King's Quest Collection for XP. I managed to update the Windows version of KQ7 to the 2.00b DOS-version with Collector's patch (http://www.tawmis.com/collector/Patches-Updat … pdates.html#KQ7).
Now I have the following problem; sometimes when I play it I get a DOS/4GW Professional error (2002): transfer stack overflow (see attachment). I get that error in 0.72 as well as in ykhwong's build. Is this a DOSBox error and if so, does anyone know how to fix it?
Reply 1 of 8, by Neville
See if using DOS32 instead of DOS4GW helps matters.
Reply 2 of 8, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
This is caused by cycles=auto. Use a fixed value.
1+1=10
Reply 3 of 8, by t0mme
DOS/32a isn't even able to start the game, all I get is a black screen.
Rigt now I'm trying the .conf settings:
core=auto
cycles=25000
cycleup=500
cycledown=500
My CPU usage is between 60 and 70% with sometimes a 100% peak. Will see if it keeps acting normal like that...
Reply 4 of 8, by collector
KQ7 doesn't need very high cycles. Try
core=normal
cycles=8000
Reply 5 of 8, by red_avatar
Wow I didn't know there was a DOS patch for KQ7. One of the reasons I never played it was because it was a very early Windows game and it ran in a tiny window. Going to have to try that patch.
Reply 6 of 8, by collector
I have only made patches for versions 1.4 and 1.51, as these are the only pre 2.0 versions I own.
Kings Quest VII version 2 updates
Reply 7 of 8, by t0mme
core=normal & cycles=8000 runs fine as well. But the menu loads faster with the settings I posted. But then again, who cares about a faster loading menu?
* Intel Pentium Dual-Core e2180 @ 2Ghz | 3GB Ram | Asus Geforce 9600GT 512MB | Vista Basic *
* AMD Sempron XP 2800+ @ 1,6Ghz | 1GB Ram | SiS M760GX | Windows XP | Linux Mint 8 *
* Dedicated DOS-machine obsolete since DOSBox 0.73 *
Reply 8 of 8, by red_avatar
Could I recommend that your patches aren't so strict, collector? I don't want to keep my DOS games on my C drive - and I don't want my Dosbox versions in my program files folder.
