First post, by 009jim
hi All
I have a DOS application that must have a dongle plugged into the printer port before it will run. Is this going to be workable in Dosbox?
Reply 1 of 6, by wd
Rank DOSBox Author
DOSBox Author
bad luck
Reply 2 of 6, by MiniMax
Rank Moderator
Moderator
Or maybe not. Isn't there a version of DOSBox floating around with direct pass-thru to the parallel-port?
Edit: Parallel port passthrough (Windows only)
_________________
Reply 4 of 6, by simons
just use porttalk drivers from:
http://www.beyondlogic.org/porttalk/porttalk.htm
run "allowio.exe dosbox.exe /a" with porttalk.sys copied to \windows\system32\drivers.
worked perfectly with my dongle based program (puls).
Reply 5 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If that made a difference then it was not the official DOSBox though...
1+1=10
