terminator future shock...yes again
First post, by patton610
specs: xp system on 620 pentium 4 with a multipurpose dvd/rw drive
dog 1.6 with dosbox .72
i get these errors:
DOS/4GW professional error (2504): can't create swap file ""
DOS/4GW professional fatal error (1011):vmm initialization error [1]
it then gives me a E:\SHOCK> prompt with E being my cd drive. i had to use it instead my mounted hard drive because it kept saying something about a missing install.dat file.
many thanks
Reply 2 of 13, by patton610
well thats the thing, I did. I actually got it installed using just dosbox without a front end, and I can see this install.dat file in my mounted directory, but dosbox does not. I the game ran once right after I installed it but without midi and everything was sluggish. I exited and could not get it to run after that. another odd thing, for which i have no explanation, is that the .dat file shows up on my cd and hard drive as autocad file. I might attaempt to change this, if i only knew what it should appear as.
Reply 4 of 13, by patton610
it seems the way around the install.dat error is to start the install program, then exit without installing it. if I do that I do not get that dat error. before i was using a directory on my c drive as the mounting location then running the game from E drive(cdrom mount) at ther moment i have started the game three times this way, but the game has a tendency to crash between missions, and the briefing screen is blacked out at first. when I move the mouse the cursor acts like a wiper and whatever I move the cursor across becomes visible
Reply 5 of 13, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 6 of 13, by vinbot1
I'm having the same problem!! This game is driving me nuts, at first I just wanted to re play it now I just want to get the #@(%*_#$ game to run!! Okay, I admit I'm a novice with emulators so here's what I'm doing:
I'm using DosBox and have it the game installed under c:\shock. Here's the command I use:
mount d c:\shock -t cdrom -label tfs
Ive also tried it this way
mount c c:\shock (THEN using)
For the love of God, PLEASE SOMEONE HELP ME!!!
P.S. - Ive also tried using VDMsound, it gets past the loader but then just hangs..
Reply 7 of 13, by dh4rm4
Why are you mounting the installed directory as a CDROM?
You should mount the installed directory as c and the CDROM drive where the original game exists (where you installed it from) as d.
As a rule, it's much smarter to mount the folders in DOSBox prior to installing a game and install the game using DOSBox, so any detection routines (sound, display, input) that run as part of the install process will work properly.
Reply 8 of 13, by MiniMax
Rank Moderator
Moderator
What is it with people these days? Can't they read? Can they only watch MTV videos?
_________________
Reply 9 of 13, by vinbot1
Ok, here's the deal. I'm not playing the game from a CD, it's a zip file from one of the abandon ware sites. Thats why I had the cdrom command mount from the game directory as theres no where else to mount it from. There is no "installation" per se, just a setup command for sound (which I did run under dosbox).
Maybe I'm missing something painfully obvious to those familiar with DosBox or maybe its a bad version of the game. As I said in my first post I'm a novice at this and could easily be missing some easy, yet crucial command.
As for the "60 Seconds Guide to DOSBox" it assumes your using a CD to begin with. I had it read to me 4 times by my GF when MTV was on commercial break. 😒
Reply 11 of 13, by vinbot1
Ahh, first I'm an idiot and now I'm a thief. I've deleted the software involved. No way to prove that of course but it's not like I can use it anyway. Thanks for all the "help". If it is a "pirate" version then I'm plainly in the wrong and I admit it (thus the deletion of it.)
However, if it was "legit" abandonware, I can only hope that when someday you people ask for help you get the same treatment you gave out. Karma's a bitch. 😈
