First post, by sirmimer
Hello 😀 after a hole night of reading i finaly got the game going ! 😁
But i still have 2 things i need help with: First. The game is not fullscreen? It's only the DOSBox little screen, how can i make it fill in the hole screen?
Two:
I want to make the auto setup for dosbox but when i try to put the code in, and save it wont let me save? i used notepad and tryed noteblok but none of them worked.
Reply 2 of 5, by MiniMax
Rank Moderator
Moderator
Fullscreen? It is explained in the ReadMe file, line 93.
Using Vista?
_________________
Reply 3 of 5, by sirmimer
yeah im useing vista..
btw. ive been looking for the cheats, found em but i cant type them in. All the sites ive seen says the same, that u have to type them in when ure at the main screen. Is that the screen were u can greate game, load game and so on?
Also, ive tryed to trype it ther, but nothing happens.. it says i just have to type... but dosnt i have to click like ctrl-c and then ther comes a box up were i can make the cheats?
Reply 5 of 5, by MiniMax
Rank Moderator
Moderator
Ahh - Vista, the bane of dosbox.conf.
You need to copy that dosbox.conf to your documents folder before you can edit it.
Next, you need to edit the shortcut you use to launch DOSBox. Instead of starting
C:\Programs\DOSBox-0.72\dosbox.exe
you need to change it into something like
C:\Programs\DOSBox-0.72\dosbox.exe -conf C:\Documents\dosbox.conf
_________________
